Electric power washer for car wash!
Old May 23, 2011 | 12:29 AM
Highlander's Avatar
Default Electric power washer for car wash!
A store near me has a rebuilt Black and Decker electric power washer on sale for $55. It comes with a wash wand and a wand with a bottle for soap attached to it. It has 1300 psi of water pressure and 1.6 GPM Water Flow.
Is this type of unit good for washing a car? Can the water pressure damage the paint? I assume this would be less than a self-service car wash put out.
Looking for your help please!
Old May 23, 2011 | 03:11 AM
Caley's Avatar
Yea! It would be good for car wash, don’t fear that about the paint. You just need to take care of cautions while washing your car with pressure washer:
1. Always keep the nozzle at least 6 inches away from the paint. Don't be tempted to get closer to remove a little spot. If you spray directly into an existing chip and you're too close, it can actually chip the paint. 1400psi is not likely going to cause any problem, though.
2. Never use a straight stream (if the pressure washer supports it). Same reason as above, Keep the stream in a "fan" of about 30 degrees.
3. Don't towel dry after washing with only a pressure washer. Even if you use soap, some dirt will remain and you'll end up with dirty towels and swirl marks.
You may check out http://www.best-pressure-washer-revi...teristics.html, It has excellent reviews about the best pressure washers selected on their characteristics.
Old May 23, 2011 | 10:13 AM
opinions only ...
is that one like they use to wash cars at the auto dealers on a daily basis? they are probably great when you have a large fleet to keep clean.
i wonder how good these are in cleaning the undercarriage, the driveway & patio furniture?
Its probably safe for top coat paint as long as you dont get too close and dont hit a chipped spot where the water pressure can get under the coat of paint and lift the paint.
JokerRides
Aug 19, 2013 03:39 PM
A2Craig
Automatic Transmissions
Jul 3, 2013 02:46 PM
Jul 29, 2009 01:35 PM
speedg1rl
Jul 25, 2008 11:21 AM
nyintheca
Jan 18, 2008 08:36 AM
