Code Bleu
I just bought a 97 STS with 118k on it. I insisted that the seller get the smog cert before I bought it. Before, there were 3 warnings on the DIS: Theft Control System Problem -- May Not Restart, Service Ride Control, & Vehicle Limited to 90 mph. After the smog test (and new radiator installation by seller) the Traction Control , ABS, & Service Engine Soon lights were on. After learning how to access the codes from this awesome site -- the Service Engine Soon light was cleared and has not returned. I noticed that the car is a lot slower acellerating at low speed because 1st gear no longer engages like it did before the smog check. Fixing that problem is my fisrt priority. I have posted the latest codes below (I didn't include the History codes). I read some of the posts -- and unfortunately, the ABS fuse is OK. What I've read says that the Traction Control & ABS lights are preventing the use of 1st gear for safety reasons.
I used to tune cars for a living in the 70's & 80's -- I was even ASE certified for Tune-Ups -- so I know the "old" basics well. This is, however, my first experience dealing with pulling, interpreting, & clearing codes. Any help would be greatly appreciated. The codes are posted below: IPC B2711: Won’t Clear B2711 - PASSKey Open/Shorted Pellet After Good Key U1255: Won’t Clear U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) RSS C1716: Cleared but returned after driving C1716 - Right Front Damper Actuator Short Circuit to Ground C1760: Won’t Clear C1760 - Left Front Position Sensor Input Fault C1783: Won’t Clear C1783 - ICCS2 DL Left Output Short Circuit to GND C1785: Won’t Clear C1785 - ICCS2 DL Right Output Short Circuit to GND PZM B2471: Won’t Clear B2471 - Interior Lamp Fault |
