Where's the oil coming from!
Old Aug 18, 2013 | 12:43 PM
BobbyZ's Avatar
Default Where's the oil coming from!
I have a 2002 Cadillac Deville, with a V8 Northstar engine, with around 110,000 miles on it. Over the past two weeks I have noticed an oil leak mostly from the right side but now more in the middle of the car. Starting around six months ago the car began to start using oil. However, I never noticed a leak. It doesn't smoke nor do I smell any oil. Twice over the past six months the "low oil" light came on and I discovered it was two quarts low each time. I refilled it and the light went off and the car has always run fine. A friend of mine said it was the valve covers leaking. He replaced the gaskets. Twice. It STILL LEAKS. However, it ONLY seems to leak once the motor is hot and once you turn it OFF. It does not seem to leak at all while the motor is running. When it does leak it last around ten minutes or so then stops. And, ONLY when it is OFF. The leak amounts to a puddle maybe three or four inches in diameter. Any ideas what is causing it and how to stop it? Thanks for any thought you might have.
Old Oct 7, 2014 | 07:15 AM
higg's Avatar
Personally I believe it's leaking where the crank case bolts together....my 2002 deville with 208,000 mile leaks in the same manner you describe. Presently the car uses a quart about every 1000 miles. I've tried different additives to no avail. The bottom of the engine was always dry until about 140,000 miles. Mine seem to leak more in cold weather than in hot weather.
BobbyZ
Aug 17, 2013 08:41 PM
edgrmndz
Feb 19, 2011 07:06 PM
td25
Feb 13, 2011 07:11 PM
1989 fleetwood
Sep 11, 2008 02:49 PM
hl8a
Big Block V8s
Sep 8, 2008 06:18 PM
