What spark plugs should I use in a 1999 Northstar engine in a DeVille?
Old Dec 11, 2007 | 10:58 AM
bighank's Avatar
Default What spark plugs should I use in a 1999 Northstar engine in a DeVille?
What plugs should I use in a 1999 Northstar engine. Owners manual says Delco 900. Haynes manual says Delco 950. Think both of these are platinum.
My LS1 NOW USES IRIDIUM plugs in place of the old platinum plugs originally installed. Old plugs had hockey pucks on the electrode which would "fall off" and get ground up by the pistons. How much hassle is it to change them?BIGHANK
Old Dec 11, 2007 | 07:06 PM
Default RE: What spark plugs should I use in a 1999 Northstar engine in a DeVille?
I suggest to stay with stock AC plugs. If you planning to a little racing or adding a power adder. Then maybe iridium plugs might be necessary. As far as changing them, pretty easy.
CaptainDeville
Apr 15, 2015 08:31 PM
Reloaded
Cadillac EXT
Apr 7, 2008 07:21 PM
brick
Jul 28, 2007 12:10 AM
kingofthe501
Nov 20, 2005 03:43 PM
trotter8
Aug 15, 2005 05:22 PM
