Vacuum check valves
Old Sep 2, 2006 | 07:56 PM
fleetwoodmack's Avatar
Default Vacuum check valves
I have a 94 fleetwood with the LT1. I need to know which way does the vacuum check valve on the driver's side suppose to face. I also have to vacuum lines that came a loose under the driver's side optispark or coil pack. One goes to the vacuum check valve the other goes to the the vacuum line right above the throttle body. Anyone know which one goes where
88Diesels
May 12, 2010 04:08 AM
MYCADYGT
Aluminum Block V8s
Sep 15, 2008 11:59 PM
MYCADYGT
Sep 15, 2008 11:54 PM
TurboLac
Aluminum Block V8s
Feb 9, 2008 12:55 PM
84CONV
Aluminum Block V8s
May 16, 2007 04:19 PM
