thanks Stomper
Old Jul 25, 2009 | 05:34 PM
llwta76's Avatar
Default thanks Stomper
For diagnosing my problem. Rep. the blower module and it seems to be working properly. I did notice that I couldn't get heat out of the system. With elect. climate control I wondering if it won't come on because the outside temp. is 80 degrees. Again though...thanks a lot for your help! Larry
Old Jul 25, 2009 | 07:45 PM
for the heater to give you heat, you have to set it at a higher temp than the ambient temp of your car.
set it at the highest it will go and report back.
Old Jul 25, 2009 | 09:42 PM
llwta76's Avatar
Hi! I set the control to 90(highest) .It's 78deg. outside this evening. I only got ambient air out of the defrost only. Working the controls hi to low only served to give me air conditioned air . No heat. thanks! Larry
Old Jul 26, 2009 | 02:03 AM
air conditioned air? does that mean cold air?
for no heat, a couple of possibilities ..
coolant level low,
heater core plugged,
baffle movement restricted
hittz
Jun 6, 2010 12:35 AM
Miss K
Jan 11, 2008 10:46 PM
theatreman
Aug 31, 2007 07:47 PM
elvis christ
Sep 26, 2006 02:39 AM
