synthetic oil saver
Do I need to explain?
Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through
your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around
your motor block where it will do more good. Oil runs cooler, and as a result, there may be
horsepower gains! $49.95
Jp500 laugh again, but after you check this out.
KaleCoAuto, Hard to find automotive items!
If this link does not work go to kalecoauto.com and click on performance items
i think oil wont freeze.
i be more concerned with the Florida folks and the oil getting too thin
with the heat.
when i get the new oil, i like to flush the old out. anyone has any ideas on how to flush that system?
