sparkplugs
Is there anything I should worry about changing the plugs in my 01 STS? Also should I use the same plug as noted in the manual. Thanks
RE: sparkplugs
ORIGINAL: infan Is there anything I should worry about changing the plugs in my 01 STS? Also should I use the same plug as noted in the manual. Thanks |
RE: sparkplugs
The reason I wanted to change the plugs is I have 90,000 miles on the car.I plan on keeping the car for a few more years and I thought I might gain some benefits from the new plugs. thanks for the reply. |
sparkplug replacement
Unless something is happening, you will most likely not see any improvement by changing the OEM plugs at this point. I believe you got 100,000 mile dual platinum plugs that can and often go double that mileage.
The old days of a tune-up at whatever mileage, gone .. the less one messes with the stuff under the hood, the better your car is. however, IF you must change them, these are the negatives: - primary wires are damaged upon improper removal, the shell material is though against heat but very delicate to physical touch. - plug cavity area is not cleaned prior to removing plugs, allowing crap to enter the cyl. - replacing with cheap plugs - I do not and will not use anything but the Delco stuff, experience. - improper gaps. - cheap spark plug loses an electrode, which in turn jams into the piston rings, which in turn destroys engine. - spark plug threads are not properly coated. - primary wires are not properly lubricated before installing. - primary wires are unmounted from the conduits and thereby allowing heat and chaffing damage. - damaging coil banks. - disturbing connectors, wiring, vacuum lines, etc. *** and my favorite *** - the job is all done, start her up and lets see if the engine can now rev to 8,000 rpm? ouch ! note: primary wires = spark plug wires Long life recommendations? probably, the best things one can do to extend the life of the mechanics in a car is to: - perform ALL scheduled maintenance, look in your Owner's Manual, - clean the engine/transmission every year (specially the underside), - change out coolant (protect your $3,000 headgasket) every other year, even if GM says not needed, - flush/change brake fluid (hygroscopic , absorbs moisture) every other year (regardless of mileage or GM's req), - add a 24oz bottle of Lucas fluid then do a transmission service (new filter / fluid, no flush), and then add a 24oz bottle of Lucas fluid upon refilling. Hygroscopic: http://en.wikipedia.org/wiki/Hygroscopic Long life for the Electrics: - buy a 12oz can of dielectric grease. - apply to every connector and switch that you ever disconnect. - make sure every harness and wire remains secured and protected. Long life for the body: Damaging rust cannot occur unless salt or moisture ac***ulates and that often requires dirt, debri, leaves or sitting water. - stick a water nozzle into every access cavity and rinse dirt, dust, etc. - dont let leaves ac***ulate. - salt? rinse and then rinse some more. - a good drive on a dry day helps get the sitting water inside panels off. *** water stains do not hurt the car, rinse even if you cant dry and buff the car. Lots of information on these are in the FAQ section. |
RE: sparkplug replacement
Thanks stomper for all the info on the plugs, guess I will wait on the plugs as the engine is running fine. thanks again
