SLS Gone to crap need some help
2 weeks ago i had to replace my alternator on my 99 slsand was told i should change the battery as well asap. so over the last 2 weeks it has been sluggish to turn over (slow cranks) finally yesterday i put a new battery in myself then turned the car on. everything went well, though i did not drive it i turned it on and let it run for a few minutes. i came outside this morning to go to work and everything turned on fine except the car would not start. i checked the battery voltage and it read 12.2 volts. My car wont start now and ive double, possibly triplechecked all wirings that i had touched. any input would be apprecitated. thanks
tell the forum a little more about your no start.... what happens? what do you hear?are any electrics working? can you pull codes?
a starter will slow crank..... and at times a bad starter wont crank, and then it will.... keep the forum posted as to whatsup
ducksducks
Mar 25, 2008 08:41 PM
