rough running
Old May 15, 2010 | 09:34 AM
mycam8u2's Avatar
Default rough running
i have a 91 deville. i replaced plugs wires cap and rotor. it still runs rough at idle and at light throttle going down the road. if i give it more than half throttle it runs good. it shutters pretty bad. if im going any speed and just go light on the gas it does it. hard on gas and it runs good. any suggestions would be helpful.. thanx
Old May 15, 2010 | 09:55 AM
How did car run prior to tuneup? How often is car used?
Old May 15, 2010 | 10:06 AM
mycam8u2's Avatar
i just bought it. it ran a lil worst before tune up. its not on the road yet. ive been working on it. i just need to figure what the prob is
Old May 15, 2010 | 10:17 AM
Are there any codes? Verify firing order and check timing is correct. Check fuel pressure. You will need Factory Service Manual (FSM) to learn how to use On Board Diagnositics to fix your car.
Old May 15, 2010 | 11:02 AM
mycam8u2's Avatar
i havent checked codes yet. firing order and fuel is good. can i use a jumper wire on the diagnostic connector to check codes or need a code reader? timing is good also. oh and the check engine light is not on
Old May 15, 2010 | 01:52 PM
mycam8u2's Avatar
i used the onboard diagnostics and this is what it showed..8.8.8, e52, e98, .7.0, f.8.5, f.8.0.. how do i clear the codes..again this is a 91. oh and this problem gets worst the hotter the engine is
Old May 16, 2010 | 04:04 PM
mycam8u2's Avatar
any ideas?
Old May 16, 2010 | 05:56 PM
mycam8u2's Avatar
well after reading some posts in here i tested the injectors. i had 4 that read less than 5 ohms and 2 that read less than 2 ohms. only 2 were in good range. so i will replace them and hopefully thast the problem..
juanssilva
Apr 21, 2014 05:03 PM
trillium
Sep 26, 2011 07:04 PM
Mr. Ectomy
Jan 10, 2009 11:02 PM
Dbergamini
Jun 3, 2007 12:29 PM
QUILTINMAN
Apr 1, 2007 10:17 PM
