Rear defroster
Old Apr 16, 2009 | 10:17 AM
schlicky13's Avatar
Default Rear defroster
Just bought an 89 Sedan Deville, but it didn't come with the rear defroster (honestly didn't know you could get a Cadillac without that feature). My question is this, does anyone know if these cars are prewired for this option? I have 2 donor cars that both had it, and I'd like to just have a glass shop swap the rear windows, and then all I would have to do is connect it and swap the climate control units. Appreciate any info you can offer.
Old Apr 16, 2009 | 10:33 AM
most cars had the same harness. too expensive to make different harnesses.
look in your trunk for a harness and a unused connector.
also, does the car have a dashboard SWITCH to active it?
Old Apr 16, 2009 | 10:59 AM
schlicky13's Avatar
The button for it is missing from the climate control unit (that's how I discovered the car didn't have it). At the very least, I assume I would have to swap in a climate control unit that does have the button for rear defroster. I won't know if the harness to the unit is wired for it until I pull the units from both cars and compare the connectors. In the trunk, I assume you mean somewhere between the rear seats and the carpet in the trunk.
Old Apr 16, 2009 | 11:11 AM
one use to be able to have a rear defog installed. some local audio shops in your area. they will be able to adapte a switch for you also....
Old Apr 16, 2009 | 11:19 AM
schlicky13's Avatar
I want to be able to use the factory switch if I can, and I guess I'm assuming it'd be cheaper to put a window in that already has the defroster lines on it, but I don't know about that.
Old Apr 16, 2009 | 12:28 PM
the installer will be able to use the factory switch if you want.
buffalosoulja
Jan 20, 2013 08:24 AM
gsk177
Dec 21, 2008 10:31 AM
wpbrink
Aug 3, 2008 11:56 AM
lenny lincoln
Mar 3, 2006 11:27 AM
EldoGlo
Feb 27, 2006 07:44 PM
