Please Help !!! 1998 sts power windows not working
My 1998 STS sat for a few weeks and the battery was to weak to start the car. I charged the battery in the vehicle. After charging, it started fine. Everything works except the windows. I checked the fuse #5 under the back seat it good. I also checked the window relay that is in the fuse block for continuity and it has continuity. None of the windows will work from any of the switches. When the window switches are toggled, their is no sound or anything. It's like there is no power or something. The outside mirrors will adjust from the driver switchs, the lockout switch light comes on and off when pushed, but none of the windows work at all.
if im thinking correctly, ur drivers door switch needs some attention. if its not working properly, the others wont . take and open door..... with your finger on the drv door window switch in the down position, slam ur door a couple time.. i now it sounds weird, but sometime it jukes the switch enough to get it working... if that works, that switch will need replaced, of course...
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
Jeff R
May 18, 2013 09:19 PM
eyeu81
May 9, 2011 09:53 AM
