P- codes
So my 2001 DeVille decides to start to act up, about 5 days after i bought it. I took it to have a diagnostics on it, and these codes came out:
P0335 P0336 P0340 P0385 P0386 P0442 P0340 P0601 now one of my friends that works at NAPA said that the gas tank cap can be the issue to P0442. I will replace that asap. Not to mention that I took out both CKPs and they had i guess oil on them, on the inside. *thinking* hmm is that supposed to be there? ok so then i cleaned it off and replaced them. as far as the evap leak, i cannot find it. hopefully it is the gas cap and nothing major. even after cleaning the CKPs the car would still studder. I honestly get nervous at a traffic light because when my car shuts off, it might take 3-5 cranks before it starts and take off. so fat I have changed the fuel filter, cleaned off the CKPs, and checked for any air leaks which i cant find and the car does the same thing. anyone else have the same issue with a solution to this problem? thanks to all who help.... SN(SW)Sandoval USS PORT ROYAL (CG 73) |
Replace crank sensors, should take care of stalling/hard star, clear codes, and post what comes back.
The CKP's are on their way from Houston. Auto Zone had them for $39.99 (each) and here in Hawaii, they are like $100 each. so after i replace them, i will change out the gas cap (vac leak) and hopefully solve that problem. Also, today when i turned my car on, the SES light was off....again and the light turns on and off randomly. i just dont understand what can be going on. i hope that it is the CKP's and not something more severe. After reading that other Lac owners have replaced the CKP's they continued to have the same issue. I will change them out and post up updates. thanks SlowRoll.
