no heat 91 deville
Old Nov 21, 2008 | 11:20 PM
cccvp1979's Avatar
Default no heat 91 deville
Has no heat at all blows cold from defrost an from floor board . I flushed the raditor an heater core . Anyone know what to do now?
Old Nov 22, 2008 | 01:32 AM
brougham1's Avatar
Default RE: no heat 91 deville
Check your heater water valve for function. Usually closed by vacuum from the programmer when in AC mode, may have stuck closed.
Old Nov 23, 2008 | 04:59 PM
carnut's Avatar
Feel both inlet and outlet heater hoses, is one warm, one cold? with engine at normal temp. Could have a large air pocket preventing circulation to the heater core. Remove radiator cap with a COLD engine not running. Coolant should overflow from neck if full. If not, start engine and have a buddy keep the idle up like 12 to 1500 RPM. Watch the coolant level till the thermostat opens, then coolant will drop quickly. Then without lowering the RPM, top off the coolant then quickly reinstall the cap. That should eliminate the air pocket.
Old Nov 23, 2008 | 05:38 PM
cccvp1979's Avatar
I tried that didnt work. When i turn the heat on the fans on the radiator come on it blows heat for a sec then stops
Old Nov 23, 2008 | 05:41 PM
cccvp1979's Avatar
Where is that?I replace the the heater control valveunder the hood no heat still. Thanks Chris
Old Nov 23, 2008 | 07:55 PM
carnut's Avatar
Try setting it to econ and 90. The radiator fan should only come on above 220 degree eng. temp that way. In auto, the compressor engages and both fan turn on much earlier. I assume the engine gets to 195 to 210 right?
Old Nov 24, 2008 | 10:58 PM
cccvp1979's Avatar
Ill try that thank u very much for the help
starbinks
Dec 25, 2007 09:59 PM
devillegirl
Feb 7, 2007 01:02 AM
bigrich831
Dec 9, 2006 01:12 AM
Angelo
Vintage & Classic Cadillacs
Nov 29, 2006 07:08 PM
Ron631
Jul 5, 2006 04:37 AM
