need transmission help
Old Apr 8, 2007 | 09:26 PM
jwrichter's Avatar
Default need transmission help
Hi, have a 2000 sts with 70k that has displayed "service transmission" readout and code of p0734 "incorrect 4th gear ratio". Car will not shift into 4th gear. Have reset codes and still have same issue. Anyone have an idea what the problem is and an estimate of repair? Is this fixable without going to cad dealer? thanks, Jim
Old Apr 10, 2007 | 07:07 PM
FLCaddytech's Avatar
Default RE: need transmission help
There is a TSB for a warped lower channel plate. (01-07-30-005A)
Driving with this condition will damagethe fourth gear band and/or the reverse clutch housing.
If you catch it early it is repairable in the car (drop the pan and remove the lower valve body/channel plate). If the band and drum is excessively worn then the tranny needs to come apart for a proper repair.
I would suggest you have a Caddy dealer do the repair.
If you know someone else who is comfortable repairingthe 4t80 unit then go for it.
Gregg Reed
Apr 13, 2014 09:09 PM
iputon
Dec 13, 2012 03:06 PM
cadillactt
Mar 12, 2008 01:31 AM
CadillacGirly
Automatic Transmissions
Oct 2, 2007 08:50 AM
Apr 13, 2007 05:34 AM
