I need your opinion Friends
Looking at a very nice 98 DeVille rust free from Arkansas. The car has been sitting but I do not know for how long without being started. The person started the car and the lifters/valves(?) were extremely noisey until the oil pressure got up. Also there was a weird noise from the exhaust but that also went away shortly after, Car has 111K. I know oil settles to the pan but is lifter / valve noise on startup normal. Thanks as always!!
Originally Posted by wkeithk
(Post 45557)
if the coolant is bad, walk away. lifter noise after extended periods of not running is common for a few seconds as the lifter's oil reservoir drains.. test test the engine compression (headgasket leak) before you decide ... . |
Thank-You
You confirmed my "gut" instinct and walked away.
