a.i.m. system
who knows about the tube that connect my heads to each other. thot i read that these were emission systems on the older 472s. Don't have a pump, big mess with the belts, but thats another story, do i need these?
Originally Posted by othello1968coupe
(Post 33624)
most everywhere I know exempts 1974 and older cars from emission tests. but you also gotta do the right things so that the engine runs well ... assuming you care for your neighbors, you can probably run even cleaner than designed by installing a good catalytic which will burn off excess hydrocarbon emissions and wont affect the engine much if any at all. |
thanks stomper.....without the pump anyway....does it do it any good? I can get a converter, but kinda need the space and just a hose and cork with some clamps.....not really cadillac style when you pop the hood. what do i do to remove it?
(Post 33634)
can you re-phrase? . |
Basically...I need the room for the alternator to travel...and it just looks ugly. The previous (owner/mechanic) weekend wrench turner just put a black hose with two hose clamps and a wooden/cork plug or dowel in the end of the hose. Can I, and how do I remove the tube? Can I, and how do I plug the holes?
