HID light problem
Old Nov 1, 2007 | 08:29 PM
mfcaddy's Avatar
Default HID light problem
I have a 2001 STS. My left xenon light flickers and goes out after it has been on for a while and until it gets warm I assume. I can turn the car off and once the right xenonlight shuts off, I can turn the car back on and the left light comes back on. However, once it goes out the first time, each retry results in a shorter time that is stays on (roughly 10 seconds). Based on the flicker, I assume it is the ballast, but don't know for sure. The dealer wants too much for the ballast in my opinion. So my question is 2 part => 1) is there something other than the ballast that can be causing the problem, 2) are there any after market kits that fit my car, are reliable and provide quality light.
Old Nov 1, 2007 | 09:09 PM
Default RE: HID light problem
Ballast is apart of bulb, and GM is proud of it. You might try to retro fit earlier non HID lamps on your car dont know if it will work.
Old Nov 2, 2007 | 08:49 PM
mfcaddy's Avatar
After digging into the headlight and removing the headlight bracket, it looks to me like there are 3 parts and in order => ballast, ignitor, bulb. The ballast is attached to the underside of the headlight bracket while the ignitor is attached to the back of the bulb. A single wire runs from the ballast to the ignitor. Without knowing which part is causing the problem I am leaning toward aftermarket HID kits. Does anyone know of a quality aftermarket kit?
Old Jan 27, 2015 | 07:49 AM
boblou's Avatar
PLEASE be careful about buying these kits. I got one off ebay and it damaged my whole electrical system on my 01 Deville. Was supposed to be new ,but after I looked at it a little closer I found it was not. the seller said he would pay to get it fixed and now he is no longer an ebay member. I`m stuck with the bill.
Old Oct 2, 2015 | 01:49 PM
Fatties's Avatar
Banned
It can be sorted for sure because of the way these things are working i am sure that keeps an impact big time.
The given suggestion is what i feel too.
ross.virant
Cadillac EXT
May 31, 2012 02:59 PM
CADILLAC DRO
Feb 1, 2008 10:45 AM
tx_boy
Dec 16, 2007 03:31 PM
g2teg91
May 31, 2007 06:56 PM
pmkls1
Oct 20, 2006 11:18 PM
