Hicks
Old Jul 15, 2017 | 06:44 PM
Adamsfamily's Avatar
Default Hicks
Can't remove key
Old Jul 15, 2017 | 06:48 PM
Default 08 Cadillac DTS can't remove key sometimes you can sometimes you can't
Originally Posted by Adamsfamily
Can't remove key
08 Cadillac DTS can't remove G and then sometimes you can
Old Jul 17, 2017 | 02:46 PM
G? Is shifter going all the way in to park? On floor shift models, if sticky fluid ... soda, sweet tea, etc is spilled on console shift plate. The mechanism on shifter can be gummed up and not allow release cable for key to move.
Old Jul 17, 2017 | 02:50 PM
The shifter seems to be going into park fine it's intermittent sometimes it happens and sometimes it doesn't when it does happen I realize that if I move the car back-and-forth from drive to reverse and park sometimes that releases it
Old Jul 17, 2017 | 02:52 PM
Default 08 cad dts
[QUOTE=Adamsfamily;53835]08 Cadillac DTS can't remove The key and then sometimes you can if anyone can help I would highly appreciate it don't know what to do
Old Jul 17, 2017 | 03:01 PM
you did say floor or column. I'm guessing floor take top of console off and look at shifter there will be 2 cables one trans and the other for ignition lock.
