heater issue
Old May 14, 2010 | 05:20 PM
mycam8u2's Avatar
Default heater issue
hello i am new here and just bought a 91 coupe deville. when i turn the heat on i cannot get any air coming out of the vents, only defrost and floor. just wondering what could be wrong. heat is good just dont know why it wont come out the vents in the dash. thank for any responses. also what refrigerant gets used for the a/c?
Old May 15, 2010 | 09:30 AM
mycam8u2's Avatar
everything works. air just wont come out the vents in the dash. only on the floor and defrost
Old May 15, 2010 | 10:04 AM
Could be as simple as a vacuum leak, typically between engine and vacuum reservior mounted on firewall. Air doors are vacuum operated. Codes may also be helpfull.
Old May 18, 2010 | 10:48 PM
mycam8u2's Avatar
air conditioning will come out of the vents.. is there a trick to get the heat to come out the dash..there is no button for the vents. only defrost
Old May 19, 2010 | 08:55 AM
System is not designed to blow heat out dash vents, There are occasions when it will happen. When outside,inside, and desired temps cause programmer to send warm - not hot - air out dash vents.
Old May 19, 2010 | 10:39 AM
mycam8u2's Avatar
ok thanx.
94--sts
May 23, 2010 07:24 PM
lenny lincoln
Mar 3, 2006 11:27 AM
EldoGlo
Feb 27, 2006 07:44 PM
centralnyguy
Dec 12, 2005 02:35 AM
Nick
Nov 20, 2005 03:39 PM
