erase codes /a.c.
Old Jun 5, 2008 | 09:04 PM
panhead jason's Avatar
Default erase codes /a.c.
thanks carnut , but how do i erase the codes related to climate control? and i had the freon checked ...they said it was full.?
Old Jun 6, 2008 | 06:30 PM
carnut's Avatar
Default RE: erase codes /a.c.
Log onto www.cadillacforums.com Go to the Sedan deVille section and click on the sticky regarding pulling codes. Good tutorial. Erase ALL codes. It will also list codes and what they pertain to (A/C, suspension, timing, etc) Or....... if you look at the forth post down just above yours, the procedure is listed. Without the compressor engaged, no shop can verify freon level.
Old Jun 7, 2008 | 01:42 AM
codes, pull, erase, tutorials are here:
https://www.cadillacforum.com/m_17425/tm.htm
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
