Coolant overflow tank
I got the "Check Coolant Level" message today on my '00 deville. It's corroded between the overflow tank and the metal piece where my fill cap screws on and is leaking. Looks like I need a new tank. I found the part ( I think) on GMpartsdirect for $63. Can any techs tell me if what I'm looking for is the "Radiator Recovery Tank", and it's part #?
Any help is appriciated. http://i41.servimg.com/u/f41/12/61/07/38/photo_10.jpg |
RE: Coolant overflow tank
yeah radiator recovery tank, coolant recovery tank, overflow tank
Coolant Recovery Kit;Will require surge tank outlet hose 25748907 & fitting 15151875, if;quick connect fitting isnt present at surge tank outlet; Years: 2000-2005 MOVED your post from sights and sounds to Gen Tech, more tech guys for you in this arena. Good luck. |
Why not save 63 bucks and try cleaning up the rust, dremel tool with wire wheel or even some 180 grit, then spray paint it. Stuff a rag in the opening to keep ourtdebris. Get a new "radiator recovery tank" cap. Just my suggestion.
I proably didn't explain it well. The metal "Flange" (part of the tank) that the cap screws onto seen here:
http://i41.servimg.com/u/f41/12/61/07/38/photo_11.jpg Broke loose like this: http://i41.servimg.com/u/f41/12/61/07/38/photo_12.jpg Also, you may notice a hole in the piece that broke off. A metal fitting with a piece of rubber hose was connected here. Is this the surge tank outlet hose and fitting? Thanks for your help! |
Indeed new part time but at least we know why you are losing coolant and yes that little hole is for the overflow.
Thanks again. I wanted to make sure I got the right parts since it takes so long to get em. Also, do you think now would be a good time to do a flush? I have heard the dexcool antifreeze is somewhat corrosive and should be flushed every few years. It just turned 70k.
The mileage is not the main issue with DEXCOOL, it is the time its been in there so changing every two years is a good practice. In your case do a change now.
appriciated.
