Code e27
Old Jun 22, 2007 | 07:49 PM
cadillackid86's Avatar
Default Code e27
Hi ive recently bought a 86 cadillac sedan deville for 100 dollars it was a still it just needed a tune up and it runs great with no major dents and all light workin except interoir lights thats a diff story. its afwd 4100 engine and the only hard code it has is E27 (i read its the open throttle signal switch). I guess the question is: is it the throttle positions switch thats in the chilton book or something else and what do i do to fix it.
Thx on any feedback.
Old Jun 23, 2007 | 07:04 PM
brougham1's Avatar
Default RE: Code e27
Hey Cad: Yes it is the throttle position sensor. If you are standing looking at the engine it will be on the left side of the throttle body. It has two screws that hold it in place and it is adjustable. Make sure all the wores are good and sound and the connections are good. Loosen the screws and adjust very slightly to the left. Check the engine performance to see if it has improved. If it has then leave it there, if not try the other direction a bit. This sensor sets the advance timing according to how much the gas pedal is pressed down. Good luck.
joshholman
Mar 13, 2010 06:25 PM
