carb problems
i have a 66 coupe de ville with a 429 bb and i cant find out why it runs rich and wont idle good. if you could give me any specs (carb settings,dwellsettings,timing) it would be very helpfull. it has a carter carb.
Hey Bro: Found a few more specs for your engine in some of my old manuals. Here we go,Dist. dwell is 30 degrees,point gap is 0.016 , timing is 5B. Also on your running rich problem, make sure that your choke is unloading after the engine gets warm. On my previos reply I forgot to mention the float setting will be 7/32. Try these things, if you need more adjustment specs for that carb. I have them. Good luck.
thanks for the info my dwell is 25deg and the timing is around 10 to 11 above i think?
on the timing mark you have a 0 then 5 then 10 marks from drivers side to pasanger it is just past the 10 and on the carter carb there are 2 small screws and 1 big one in the middle what is the middle one foe and what are the settings on those i adjusted the flotes to 3/8and it helped but wont idle smooth entil 1000 to 1200 rpms
Hey eye poppin: You still might be a little rich on the float adjustment. You should have aa air adj. screw, a fuel adj. screw, and a idle speed adj. screw. Only do carb. adjustments if you know that the engine is in tune. All settings to factory specs. Turn your air and fuel screws in all the way until they seat gently., then back them out about 6 turns and starts the engine to do your final adjustments by going clockwise 1/4 turn at a time until optimum idle is reached. The choke should be held to the full open position and the engine should be warm. You could also try opening your points gap a little which will change your dwell slightly. Chow for now, D. What is the status of your fuel pump? Lots of pressure.?
original fuel pump still mecanical did not check pressure.i found the high idel screw on the side. the two small screws i assume are the air fuel, but still dont know what the large screw in the middle is for. the choke is opening when it warms up. am i right in assumeing the timing is 10 to 11 deg above tdc? thanks again for all the help
yes thats it 66 coupe deville full air ride & 20" wheels. not a bad start i think. i have done all the work on it so far.im just hopeing to get it running better so i can drive it. at 5degbtdc the car wont hardly run the motor is old and has not been rebuilt. i havent adjusted the adjustment screws in the carb yet because i dont know what the middle large screw is for.
moobymuffin
Mar 4, 2009 02:05 AM
