CAN SOMEONE SHED SOME LIGHT ON THESE TSB'S?
Old Sep 23, 2007 | 03:33 PM
jd3772001's Avatar
Default CAN SOMEONE SHED SOME LIGHT ON THESE TSB'S?
IM HAVING SOME FRONT END VIBRATION ISSUES...ABOVE 60...AND MORE AT 70...THEN GOES AWAY AROUND 80. IM THINKING THE TIE-RODS MAY BE LOOSE. BUT I DONT KNOW. AND THE MOAN PROBLEM IS A CONCERN OF MINE TO.. ANYBODY KNOW WHAT CORRECTIVE SOLUTIONS WERE FOR THESE TSB'S OR WHAT WAS FOUND DEFECTIVE?
2001 Cadillac Deville
Bulletin #:
030232049
Sequence #:
10004765
Date:
11/01/2003
Component Name:
017500 steering:linkages:tie rod assembly
Make:
Cadillac
Model:
Deville
Year:
2001
Summary:
Release of new outer tie rod ends for service. *tt
Bulletin #:
250102
Sequence #:
629720
Date:
01/25/2002
Component Name:
015000 steering:hydraulic power assist system
Make:
Cadillac
Model:
Deville
Year:
2001
Summary:
Concerns with power steering moan condition at low parking lot maneuver speeds and when maing right hand turns. *tt
Old Jun 5, 2014 | 08:56 PM
donsueromeo's Avatar
My 2001 Deville had this same issue and previous forums said 50% it's your tires and wheels balance issue - the other 50% said it's your motor mounts. After spending $500 for new rims and $600 for new Michellin Tires and get dynamic balancing etc. also changed all brake rotors and air ride shocks it still vibrated. Then someone talked me into the trans being rebuilt for $1200 and at that time the trans mechanic said "by the way I changed you motor mounts" and the vibration went away.
Joe2002DeVille
Jan 11, 2016 06:32 PM
H.O. Driver
Sep 15, 2009 09:30 AM
CadZZilla
May 20, 2009 04:32 PM
Caddyman77
Apr 10, 2008 09:32 AM
tommy
Sep 6, 2007 11:02 PM
