A/C not working
ok i have a 94 sts the a/c is not working it has a full charge of a-134a the compressor turn on and then off every20 sec's or so but will not keep running any ideas???????????
thanks |
RE: A/C not working
dont understand question ... https://www.cadillacforum.com/m_9792/tm.htm ORIGINAL: l306x ok i have a 94 sts the a/c is not working it has a full charge of a-134a the compressor turn on and then off every20 sec's or so but will not keep running any ideas??????????? thanks |
RE: A/C not working
not sure what you do not understand ...i turn on the a/c in the car open the hood look at thecompressorit will run for a second then stop 20 seconds laterthe clutch will turnonfor a few seconds then turn off
ant ideas? thanks |
RE: A/C not working
Do you have a set (high and low pressure)of gauges to aid in the diagnosis?
How did you determine it has a full charge? Have you checked for codes? What is the temp coming from the vents? A/C systems have so many elements just posting a one line question makes it near impossible for anyone to help. |
RE: A/C not working
ORIGINAL: l306x not sure what you do not understand ...i turn on the a/c in the car open the hood look at thecompressorit will run for a second then stop 20 seconds laterthe clutch will turnonfor a few seconds then turn off ant ideas? thanks It is a normal part of how this system works. The frequency may indicate a problem but if the compressor runs constantly that would indicate a problem also. |
RE: A/C not working
Did you even read this link???
examples of no-way-we-can-help questions: "my car dont run well, what is wrong with it?" "my A/C aint working, what do i do?" "my car stalls, do i need to take it to a dealer?" #5. On some issues, specially with A/C & airbags, we are very reluctant to provide suggestions unless the owner can convince that he/she knows what he/she does with such devices. |
