99 Deville
Old Jun 19, 2008 | 02:27 AM
adixon3's Avatar
Default 99 Deville
I've had to replace my starter 2 times in 2 weeks because it keeps breaking the support that holds the bearing at the end of the starter bendix shaft that supports the shaft.The guy at the autopart store said he thinks I need a tune-upthat is causing the flywheel to rotate backwards for short period when starting and that's why theshroud thatcovers the starter bendix keeps breaking. The car also has a misfire and is loosing water somewhere I have to keep adding water every 2 days.
Old Jul 13, 2008 | 04:32 PM
adixon3's Avatar
Default RE: 99 Deville
I have a blown head gasket so I decided to just replace the engine.
Old Jul 13, 2008 | 05:29 PM
carnut's Avatar
cracked or broken flex plate. you will see it when you remove the engine.
Old Aug 6, 2008 | 12:31 AM
allenfre's Avatar
Ayways, aside from a few styling boo-boos the 1999 DeVille is a vastly improved car over my 1994.
__________________________________
Powered by Autopartswarehouse.com
