98 Catera Problems
Old Nov 8, 2006 | 03:04 PM
lruss_16's Avatar
Default 98 Catera Problems
I have a 98 Catera the check engine light is on and i took it to Autozone and received the trouble code p0508. Says me voltage signal for the electrical circuit of the idle control system is too low. I changed the air filter, put in some fuel injection cleaner and is still on. MY question is could it be the a/c compressor? Because the air conditioner doesn't work either. I know that a/c compressor can have an effect on the idle system.
Old Nov 8, 2006 | 03:17 PM
FLCaddytech's Avatar
Default RE: 98 Catera Problems
I don't show a P0508 listed for 98 catera???
Old Nov 8, 2006 | 07:56 PM
lruss_16's Avatar
this everything that was on the sheet
Troublecode OBDII (Alpha) P Code
Troubleshooting P0508
The PCM has determined that the voltage signal for the electrical circuit of the idle control system is too low for the current engine operating conditions.
Old Nov 8, 2006 | 09:05 PM
Thats weird. i checked 97, 98 and 99
There is a 505, 506 and 507 but no listing for a 508.
They all deal with the idle circuit but without a detailed explanation of the code failure conditions i could only guess at what was causing the light.
Sorry i can't help more.
Old Jan 13, 2007 | 08:08 PM
OldBikeDad's Avatar
Does the low voltage mean low idle?
If you AC compressor was bad and loading down the system, that might cuase a low idle.
Do you have a serpentine belt, or can you isolate the compressor?
Dave
Cadillac-Catera
Jul 18, 2022 12:40 AM
keithm
May 28, 2017 03:05 PM
IA_catera
Aug 12, 2010 12:49 AM
DRF
Jan 3, 2008 05:52 PM
kmarchet
May 8, 2006 03:04 PM
