95 ETC displays starter disabled code pcm 109&052
:confused: I have a 1995 ETC that messaging me that the starter is disabled and I should take the key out and wait 3 minutes to start, but it doesn't. I checked the DTC and it displayed P109..keep alive memory reset PCM lost primary battery power and P052...PCM memory reset.
Is there a method to correct this problem on OBD 1 equipped cars without having it hauled to the dealer? Thank you:D |
It sounds like full battery voltage is not getting to the PCM. Use a voltage meter to check the voltage at your battery. If that is 12.5 volts or better, then check the voltage from the battery negative to each of the fuses in the fuse blocks. Hopefully, it is just a bad connection somewhere that is causing a loss of volts.
Originally Posted by 2001_Seville_SLS
(Post 38428)
Originally Posted by sixturbo
(Post 38430)
Thank you... I will work on it and let you know what I come up with.
Do you have any other thoughts? Thank you. Greg |
Pass Key fault - wont set codes on earlier models. Ignition cylinder most common cause, can be tested with dealer tool or OHM meter. If if you measure resistance of key by itself, then measure value at 2 small white wires on steering column wiring harness as cylinder is rotated. If reading drops out while cylinder is rotated - it is the cause. You will new new cylinder and correct key(s) blank. Blank will be the same as original, but it will be cut for new cylinder.
Originally Posted by slowroll
(Post 38437)
(Post 38437)
The little white wires are in the block 6 inches or so from base of column. Wires are made to cylinder which have to be run down column and inserted in to connector, then connector is attached to block. Block halves then bolt together with 7mm bolt. If you have FSM go to pass-key or theft deterent section. Steering column repair is in section 3.
(Post 38444)
Thank you |
