92 STS Spark plug install advice please!
Old Feb 21, 2011 | 07:38 PM
blowingupjake's Avatar
Default 92 STS Spark plug install advice please!
Hey everyone!
I'm here on behalf of a freind with no mechanical ability and very shallow pockets.. Long story short- I need some advice to get the plugs in and out of the firewall side of the motor. Its a tight fit and I have big hands- Is the only solution lifiting the engine partially out?
Thanks in advance for any tips- I'm totally out of my element here, I'm used to the import scene.... So I need all the help I can get HA!
Jake
Old Feb 22, 2011 | 06:34 PM
Originally Posted by blowingupjake
Hey everyone!
I'm here on behalf of a friend with no mechanical ability and very shallow pockets.. Long story short- I need some advice to get the plugs in and out of the firewall side of the motor. Its a tight fit and I have big hands- Is the only solution lifiting the engine partially out?
Jake
dont you hate those transverse drive trains?
you didnt say how many miles the plugs have ..
here is some generic suggestions that work in many transverse engines ...
1st wash the engine down .. u dont want crap falling into the cylinders
put the car on a lift and get to the plugs from the underside .. you will need good quality sockets (thin) and ratchets .. the cheap tools probably wont fit ...
or
undue the mounts and jack up the engine with lots of care.
or
lay on top of the engine (with care and use a fat cushion from a patio chair), clear everything that is removable and you should be able to get to them .. this is my preferred way and has worked on every car i had ...
since you know how hard the job is, assuming this is not a race car or a stunt car, i also suggest that he stays with DELCO OEM plugs as called for by GM .. nothing else will give you any better performance or reliability.
coat the plug ends with di-electric
Old Feb 22, 2011 | 07:11 PM
or
or
I hate transverse v8s, thats for sure! He's got about 70k on these plugs, I did convince him to invest in the factory replacement plugs..It's far from my first rodeo, just my first on a crammed cadillac bay! I Was wondering about trying to get them from underneath, I'll give that a try. I really appreciate the input!!
Jake
Sparkplugs.com
Aug 1, 2007 12:05 PM
goldseal
Jun 4, 2007 04:30 PM
Apr 20, 2007 02:13 AM
michaeldkania
Sep 19, 2006 11:29 AM
michaeldkania
Sep 18, 2006 11:45 AM
