2005 cts-v trunk leak
Old Oct 9, 2009 | 06:57 PM
bowtie8's Avatar
Smile 2005 cts-v trunk leak
MY trunk is taking on water from somewhere,
The whole spare tire area was full of water and carpet wet
I pulled the carpet, and dried it out, the floor looks good, I don't think its coming up from bottom nor do I think its coming in via the weather stripping on the the trunk lid.
very weird. Does anyone have a drawing of the tail light assemblies, I'm wondering if its leaking down thru them like I'm missing a boot or something, The carpet is very wet in both rear corners at the base of the tail light assembles.
thanks
JW
Old Oct 10, 2009 | 01:06 PM
bowtie8's Avatar
Default Fixed
THANKS FOR ALL THE RESPONSES
After gutting the trunk and looking things over for leaks, it was not obvious of where the water was entering.
I proceed to flip the back seats down, and cover the complete trunk with newspaper. This would allow any drip that made it in, would show me exactly where it was coming from.
From here, I took the garden hose and duct taped it to the roof of the car with the water flowing down on the back window
I checked the weather stripping for the trunk lid...perfect, no leaks
Then bingo the vertical seals on both sides of the rear window, blown and leaking.
With the garden hose the water roared into the trunk assemble, down thru the seal by the horizontal base attached to piller.
From hear I attached suction cups to the window and it was obvious that the seal was gone.
Now getting the window out and repairing with 3M Windshield sealant is another conversation.
best
John
Old Oct 10, 2009 | 02:03 PM
With the garden hose the water roared into the trunk assemble, down thru the seal by the horizontal base attached to pillar.
best
John
sorry .. i didnt see this thread. the software settings of this site tend to not show us a lot of things. I have repeatedly requested a different setting but it hasnt happened.
there are several threads with the same subject, CTS trunk leakage.
the usual problem tends to be the pillars as you found out on your car.
Old Nov 29, 2009 | 07:52 PM
acefreley68's Avatar
Default Trunk Pool
I had the same problem recently and took it to the dealer. Said the sunroof drains were leaking into the trunk area. They drain to the back of the vehicle behind the tail light assy i believe. I have not seen them myself but it follows. Had more water inside the car by driver A pillar and again sunroof drains clogged. Good luck!!
Old Nov 30, 2009 | 06:31 PM
Mrmojorisin's Avatar
Dont think an apology was required Stomper. It was only like 18 hours since he posted. Talk bout impatience. Specially seein as a search could have helped him out from the get go without even having to post. But kudos to you any ways.
Quite admirable of you.
ramos89
Jul 16, 2013 01:24 PM
undertaker78
Jun 25, 2010 07:39 PM
jdash
Jul 17, 2008 09:18 AM
lferrebee
Aug 23, 2007 04:36 PM
