2004 Deville issue with INTERIOR LIGHTS
Originally Posted by 5150johnny
(Post 30141)
Hello all....this morning fired up the 02 seville and noticed the exterior light were not on..only daytime lights..opened the door and no interior lights went on....manually turned the lights on and the exterior lights went on, but no interior with the door open. was able to manually turn the overhead lights on by pushing the switch....also with the exterior lights on manually the interior stereo, heat/ac controls button lights did not work....checked all the fuses all look good....coudl it be the twilight switch? the dimmer dial does not work also.....
(Post 30427)
at night i have no radio button lights....window button lights....no interior lights when i open the door...and the dimmer does not work....also i have to manually put the lights on...i also swapped out the light switch with another one and same results....
Originally Posted by rickyd
(Post 30417)
how about at night? do the lights (all) work at night properly?
rickyd |
im at a lose..... i'll see if slowroll can jump back into this post and maybe he'll have a glue what the hay is goin on
rickyd |
what year is your car?
Originally Posted by slowroll
(Post 30460)
"5150johnny" has a 02 seville, "cadillac al" has a deville but cant find the year |
(Post 30471)
5150johnny with courtesy lights - is switch in overhead console in off, auto, or on. Since you have some access to Tech2 - what does Twilight Photocell data read in IPM. If you are not get Headlights Suggested - message photocell maybe skewed - telling modules it's daylight. photocell data should change with light, on sunny day cover photo cell, wait 30 sec.,and see what data is, then uncover, wait 30sec.,and see what it reads. If data changes - post what reading are, if it doesn't or very little - sensor or connections to are where to look. Cadillac Al refresh me to what year and model Deville.
The lower door lights (puddle lights) never turn on. When I open the doors in the dark, the interior lights don't turn on. Only the door unlock, power window and heated/cooled seat lights light up. I can manually turn on the map lights and rear map lights with the push button for each light. My dash/radio/climate control lights dim if I use the dimmer control but none of the map lights turn on when I move the control all the way over like they should. When I use my remote to unlock the doors in the dark, the outside lights turn off as soon as I open a door and the interior light, map lights etc. don't turn on. I'm assuming my door switches are good because if I turn off the car while the radio is on, the radio shuts off when I open a door. Also like I mentioned above, the outside lights turn off when I open the doors. I don't think I'm forgetting anything. My trunk lights and glove box lights both work. I checked all the fuses and the relays that are associated with the interior lights. Again, please help me if you can. Thanks a million. |
Try disconnecting battery touching cables together to reboot/reset modules. Are you losing exterior lights also except in manual operation? STS and Devilles are little different as how they make things work.
(Post 30613)
