1999 eldorado headlights
Hi all, I have a 1999 Eldorado and I have been having the same problem for over 2 years now...My headlights keep failing, the relays keep blowing and noone can figure out whats wrong. The dealer had it,replaced all the relay switches(1,000$ later)a few months later no headlights, when you pull the hibeams on, you get nothing.(Foglights and running lights ok) I had a privet guy work on it 3 times..same results. Now its at an electric shop for the second time..Does anyone have any idea why these relays keep blowing?? I love my Eldo and its in top condition(except this lighting issue) Please help if you can...Thanks
RE: 1999 eldorado headlights
has anyone tested the ALTERNATOR ? |
Noone said they checked it.Wouldnt I knotice any other problems, if the alternator was acting up?
this is not conclusive, but relays, fuses, and filaments burn out with either power surges that can overload or LOW voltage which increases the line load a car has TWO power sources.... battery and alternator after wiring and connectors (including GROUNDS & SHORTS) , the next item in frequency of problems with electricals is the power source. assuming your battery can steadily produce acceptable voltage, next in line is the charging system - alternator being the main unit. |
my battery is new, a few months old. I keep telling the guys to see if there is a short in the wiring somewere, Ill be calling them on Monday so Ill make them check the alternator.
I called the guy working on my Eldo and he has taken the relay switches off and found corrosion on one of them. This isnt the first time for the corrosion issue. were is the relay box located? and what could we do to prevent the corrosion?
Have the guy working on your car to coat all connections with dilectic grease.
