1998 Deville load leveller question
Old Sep 17, 2007 | 08:33 AM
jvoortman's Avatar
Default 1998 Deville load leveller question
I have a 1998 Deville, and over the past couple months the load levellers seem to be dying. Sometimes when back seat is full it doesn't lift up (and it bottoms out when pulling out of driveways), and recently there is a terrible rattling sound coming from the rear end. The upside is when the rattling does happen the car does lift up, but when the rattling doesn't occurthe car doens't lift up to the normal driving position. Is there an inexpensive fix anyone can suggest? A freind suggested seeing if it were possible to put in some air shocks that would be filled up manually with an air hose at the gas station. Thank you for any help you mayoffer!!!
Old Sep 17, 2007 | 09:55 AM
Katzmans Caddy's Avatar
Default RE: 1998 Deville load leveller question
The compressor is very accessible in that car, drivers side rear behind the lower quarter panel, a black box.
Old Sep 17, 2007 | 11:03 AM
jvoortman's Avatar
can I get a replacement from a wrecker, or is this something I should get from a dealer?
Old Sep 17, 2007 | 02:41 PM
http://cgi.ebay.ca/1997-1999-Cadilla...QQcmdZViewItem
I would check at the wrecker as well. The dealer will have a new GM part which will likely be very expensive but why not call and ask.
Old Sep 17, 2007 | 06:02 PM
_X_CaddyTech's Avatar
also be a good idea to check for leaks, i noticed that a lot of the pumps went bad b/c they were continuosly running b/c there was a leak in the system. it is n ot vey hard to trace the lines.
Old Sep 17, 2007 | 07:12 PM
jvoortman's Avatar
yeah, they only want $1,100.00 + taxes OUCH!!!
Old Sep 17, 2007 | 07:42 PM
Ok, that makes no sense, the eBay link I gave you had it for $155, How can the partbe 8 times more at the dealer? Two or three yes but 8![:@]
Old Sep 18, 2007 | 07:57 AM
jvoortman's Avatar
oops, I never saw the link, I will be buying it off there. The dealership wanted $1,100.00 and $288.00 if it was a relay, and of course installation and taxes would be extra. This is the dealership who wanted that much. Thanks to you all!!!!!!!!!!!!!!!!!!!
" src="http://canada411.yellowpages.ca/images/listingArrow.gif" width=9 border=0>
Frost Pontiac Buick Cadillac Ltd - 905-459-0126
320 Queen E , Brampton , ON L6V 1C2
Old Sep 18, 2007 | 08:23 AM
Hi jvoortman, I sent you an e-mail, check your inbox.
unltdecko309
Jul 19, 2009 11:58 PM
trakspeed
Jul 8, 2009 06:56 AM
plat850
Nov 28, 2007 09:39 PM
Davids DTS
Sep 24, 2007 12:31 AM
Davids DTS
Jul 31, 2007 06:59 PM
