1997 eldorado transmission
Old Mar 29, 2011 | 11:14 AM
NOW-YOU-KNOW's Avatar
Default 1997 eldorado transmission
MY 97 ELDORADO'S WATER PUMP HOUSING WAS LEAKING SO I REPLACED THE 4 GASKETS BETWEEN THE ENGINE AND THE HOUSING AND I REPLACED THE WATER PUMP MYSELF.(NO LEAKS ANYMORE...AFTER PUTTING EVERYTHING BACK TOGETHER I NOTICE THE TRANSMISSION WONT GO INTO DRIVE OR REVERSE SO I ADDED A QUART OF FLUID BECAUSE THE DIPSTICK WASN'T READING ANY FLUID....AFTER CRANKING THE CAR I PULLED THE STICK FOR THE TRANNY OUT AND FLUID BEGAN TO BUBBLE OUT ALL OVER THE GROUND IT WASN'T HOT IT WAS COOL IN TEMPERATURE (A COUPLE OF QUARTS CAME OUT) WHEN I PULL THE STICK OUT NOW IT SHOWS BEYOUND THE FULL MARK..TRANNY STILL NOT ENGAGING IN REVERSE OR DRIVE....HELP WHAT SHOULD I DO.
Old Mar 30, 2011 | 07:19 AM
Adams' Apple's Avatar
Perhaps when removing/replacing the coolant crossover housing, you somehow dis-connected the shifter linkage for the trans.
The fluid "burping" out of the trans is most likely due to you overfilling it when you added the fluid.
I would carefully check the shift linkage on the top of the trans first, and go from there.
musique
Jul 26, 2008 05:26 PM
Caddi06
Jun 2, 2008 07:47 PM
marsprev
Mar 13, 2008 12:48 AM
pmakki
Nov 24, 2007 08:45 AM
alfailak
Feb 19, 2006 11:25 PM
