cadillac stalls, intermittent, eghosts / connectors ?
Old Feb 27, 2011 | 03:48 PM
etbracket's Avatar
Default cadillac stalls, intermittent, eghosts / connectors ?
Hi im new here. I have a 99 deville and im having trouble with the car stalling. When it stalls i pull the ing 1 fuse out put it back in and the car fires back up but it will not stay running that long. I think that controls the electronic ignition module. Could that be going bad or is in my ecm? Any help would be appreciated.
Old Feb 28, 2011 | 02:49 AM
Cadsforfun's Avatar
Default Stalling......
Some things to check, full filter,temp.sensor connection or sensor,not sure if you have the idle air compensator solenoid on that model year, if you do that can cause stall. Crank sensors, ignition connections. Good luck.
Old Feb 28, 2011 | 05:42 AM
etbracket's Avatar
I dont think its a crank sensor there is no check engine light. When it starts and runs for about 5-10 min I hear a stumble right before it shuts off, then I'll either pull the ing 1 fuse or the dis fuse and it will fire back up. Im wondering if it is the ignition module or the ecm because the dis is the module fuse. Do not want to bring it to the dealer!
Old Mar 2, 2011 | 07:33 PM
gmtechs's Avatar
crank sensors dont always set engine codes
does the car run
when does it stall
Old Mar 3, 2011 | 05:32 AM
etbracket's Avatar
Yes the car runs. Ive had it stall while driving. Pull the dis fuse for the ignition module and starts right back up. Very weird now car is running fine for the last few days.
Old Mar 3, 2011 | 05:39 AM
etbracket's Avatar
Forgot to say i pulled all the connectors off the ignition module after writing first post and the car has been running fine dont know if its a fluke will see what happens.
Old Mar 3, 2011 | 08:18 AM
sounds like a connector problem .. it may well return .. read e-ghots thread in our FAQ ...
did you apply dielectric to the connectors?
Old Mar 4, 2011 | 05:31 AM
etbracket's Avatar
No i did not but i will put some grease on the connectors. There is one thing i dont understand is why when this was happening i would pull the dis fuse out and then put it back and the car would start. Hmmmm very confusing. Thank you for your help.
Old Mar 22, 2011 | 05:55 AM
etbracket's Avatar
Put grease on connections worked fine for a couple of days but still have problems. Tested to see if i have power at the ignition module when this happens and i do then i pull the fuse for the dis put back in and the car starts. Im so confused why this is happening. Ignition module problems or ecm?
Old Mar 22, 2011 | 06:44 PM
gmtechs's Avatar
any codes ?
use the in car to check unless u have a tech 2
