85 Eldo hot start problem
Old May 11, 2014 | 09:34 AM
tmd171's Avatar
Default 85 Eldo hot start problem
my problem is hard starting my '85 eldo when hot. The problem occurs when the car has been driven then stopped for a short period, it's difficult to restart. The problem appears to be fuel vaporizing, or vapor lock. Fuel pressure holds steady at 10 psi while cranking but little/no fuel from injectors. Bleeding off fuel from the pressure line comes out foamy a couple ounces then clears and car will start and run fine. Filter has been replaced, pump is assumed ok as pressure is normal.Any ideas are appreciated. No codes, all sensors within specified range.
Old May 12, 2014 | 05:48 PM
Fuel level? Is gauge accurate? Contaminated fuel?
Old May 13, 2014 | 08:12 AM
tmd171's Avatar
problem occurs with fuel full or low. I did notice when I bled fuel recently it looked old and dark. The car sat all winter so it might just be old, or something is breaking down and contaminating it. My plan is to take the tank out and get a good look inside, I'll replace the pump and filter and cross my fingers.
Old May 15, 2014 | 09:21 PM
not a bad plan, tank comes out very easy actually
chasguy
Apr 25, 2011 04:41 PM
Mags1
Nov 19, 2010 07:37 PM
mmayer
Sep 2, 2008 11:34 PM
842heat
May 5, 2006 10:20 PM
