torque specs
Old Jun 2, 2007 | 09:36 PM
daddilac's Avatar
Default torque specs
Hello there i need the head bolt torque spec for my 1993 4.9 liter caddy please and thanks
Old Jun 2, 2007 | 09:39 PM
daddilac's Avatar
Default RE: torque specs
and what can i do to increse my horsepower?
Old Jun 2, 2007 | 10:12 PM
G.A.R.Y.'s Avatar
Not where I can look up torque specs at the moment. As far as hp increase, how much do you want to spend?
Old Jun 3, 2007 | 02:24 PM
daddilac's Avatar
not to much not quite wealthy and i need those torque specs to put it back together
Old Jun 3, 2007 | 04:08 PM
G.A.R.Y.'s Avatar
For not much money try our sponsers Magnaflow exhausts and K&N air intakes. Perhaps Florida super chips, among other things. I am still not where I can get to torque specs, try to pm flcaddytech on this board. Just find his name anywhere click on it and send pm. If that is not successful I will get you some info, but it won't be for a day or 2. Hope this helps.
Old Jun 5, 2007 | 12:00 AM
daddilac's Avatar
well i got the specs for the head bolts now a need the specs for the rocker arms but thanks for the info
Old Jun 5, 2007 | 12:41 AM
this is what i show for GM alum engines:
Rocker Arm
Studs ( Aluminum head ), 50 ft. lbs.
Cylinder Head Bolts w/Hardened Washer : Long 65 ft. lbs. Short 60 ft. lbs.
Intake Manifold 25 ft. lbs.
Valve Cover Bolts 25 inch lbs.
keep us posted ...
ORIGINAL: daddilac
Old Jun 5, 2007 | 02:09 PM
daddilac's Avatar
i'm not to sure butI dont think my block is alluminum? not to sure though but i did end up snaggin those torque specs. thanks anyways though. keep me posted on any goods around here.
Old Jun 5, 2007 | 02:17 PM
last time i checked, this whole family of engines was aluminum.
Aluminum OHV [ul]HT-4100
HT-4500
HT-4900[/ul]
ORIGINAL: daddilac
Old Jun 6, 2007 | 08:25 AM
daddilac's Avatar
dang........i guess you do learn something new every day!
