engine noise
Old Aug 24, 2008 | 08:58 PM
brutis5's Avatar
Default engine noise
I got a 2005 cts. its got a noise that sounds like a rod knock, but when i put it on a lift and listen from below it sounds like its up higher in the block. when i listen closely to the driver side valve cover, i here it the most. What (if anything) could sound like a rod knock in the d.o.h.c. head. thanks nick....[8D]
Old Sep 11, 2008 | 01:04 PM
1989 fleetwood's Avatar
Default RE: engine noise
i think it would be more of tick if it was coming from your valves. is the knock deep sounding? is it a double knock?
Old Oct 17, 2008 | 01:29 PM
Big5DoubleZero's Avatar
You could have a bad piston pin making the noise. Maybe bad valve spring causing lifter knocking. Is it fast or slow sounding?
tommygunner06
Sep 20, 2007 12:16 PM
Lumpuck
Mar 8, 2007 02:13 PM
Bstdevo9
Nov 28, 2006 04:33 AM
Lumpuck
Aug 12, 2006 12:39 AM
