Hubcap locks
Old Oct 1, 2007 | 10:07 AM
docphil's Avatar
Default Hubcap locks
I have just inherited my mom's '89 El Dorado Biarritz, with 35,000 miles on it. It's in great shape, but needs new hubcaps. I have a source for the hubcaps, but is there a way to lock them to prevent theft?
Old Oct 1, 2007 | 12:44 PM
Default RE: Hubcap locks
docphil......1st are the hub-caps original equipment? or after market caps that will fit.....usually the source will answer that question......if they are aft mkt..... oh welcome to the Forum........ did you go to Member introduction?? check it out..... also go to Off Topic, be counted in Cadillac Demographics..... again welcome
Old Oct 1, 2007 | 01:03 PM
Katzmans Caddy's Avatar
Most OEM would come with locks for that car, especially the wire wheel covers.
Oh, nice inheritance!
Old Oct 6, 2007 | 10:56 AM
Factory wire wheel covers all had locks since the early 80s. It consisted of a cone that was held on by 3 of the lug nuts it could have either a stud or nut at the top and a locking screw or nut depending on cone.Center cap covered lock.If you a missing locking part try to find complete set: covers,locks, and cones.Car should have 15" wheels and 89 - 95 fwd covers should work.NOTE : cones are not universal so, the correct cover is somewhat important,and on some model the the lock is the only thing that holds the cover on the wheel.Also the wire wheels covers of the 80s tended to squeak while driving which can requires some tweaking to get rid of the noise. Hope it helps
ooshock
Jan 12, 2015 09:46 PM
79CaddyFleet
May 11, 2007 10:06 AM
la_uno_y_unico
Mar 7, 2006 11:26 PM
simjack
Jan 9, 2005 10:04 AM
simjack
Sep 16, 2004 08:56 AM
