HELP on damper pulley removal
Old Jul 29, 2011 | 06:17 PM
91bairritzwa's Avatar
Unhappy HELP on damper pulley removal
HI I have a 91 eldorado biarritz 4.9, i had water pump failure and replaced and found water leak behind water pump coming out of what appears to be the water pump inlet gasket so i took the water pump back off and to get the front cover off to replace that gasket i need to get the damper pulley off. The chilton manual shows 4.5 to jack car up and lower r.s. engine cradle...4.9 shows to just pull the pulley...I have 4.9 with no cradle and no clearance to pull the damper pulley...do i need to lift the body from the frame?? and if so any thing i need to remove or disconnect?? and suggestions or answers would be greatly appreciated....
Alex in SLC
Aug 30, 2014 10:27 AM
kholland
Nov 1, 2007 05:30 PM
Oct 20, 2007 07:59 PM
jxer00
Oct 3, 2007 05:08 PM
jholland250
Mar 19, 2006 05:39 PM
