1980 Biarritz fuel problem
Old Dec 11, 2012 | 06:15 PM
Deathangel's Avatar
Smile 1980 Biarritz fuel problem
Please help I have 1980 Biarritz 368 the motor is running super rich,I did spark plugs,cap,rotor,gas filter,air,oil,spark wires ,set timing at 10 degrees,check vacuum lines,I noticed spark plugs on rt side of motor are turning black the rt side is ok.i put new exhaust on I had to take it of from catalytic converter cause it was turning orange.it shoots blue flames out. Pipe from manifold,somebody please help what could it be.tim 973- 349-4941 or post please
Old Dec 16, 2012 | 05:23 PM
jimkf's Avatar
If just one side shows black spark plugs you either have an injector running too long which is letting in too much fuel or an issue with fuel pressure. The issue with the converter getting hot and turning orange is due to all of the unburned fuel getting dumped into it.
Kim C
Jun 26, 2013 06:29 PM
Deathangel
Dec 9, 2012 06:26 PM
Deathangel
Dec 9, 2012 06:25 PM
jfam
Feb 16, 2012 08:46 PM
peace707
Dec 7, 2006 02:05 AM
