1991 Ford Mustang LX Coupe complete or rolling
347 with 70mm turbo, powerglide
Above Added: Sun June 4, 2017, 10:02 am EST
I have a 1991 Ford Mustang LX Coupe for sale.
Engine:
347 stroker, dart 4 bolt main block
9.5 to 1 compression
afr 195 aluminum heads
cam motion custom cam
eagle rotating assembly
melling oil pump
pro mustang spyder efi upper intake
eldebrock victor jr lower intake
bbk 75mm throttle body
pmas mass air unit
diablo mass air extender
7 quart oil pan
many more parts call for details
ignition:
stock distributor with msd cap and rotor
ford racing plug wires
thermotec heat resistant spark plug wire boots
ngk spark plugs
msd 6al digital ignition box with rev limiter
msd 2 step
msd blaster efi coil
fuel system:
factory fuel tank sumped
aeromotive a1000 series fuel pump
aeroquip fuel hoses
ford racing 90lb fuel injectors
aeromotive fuel pressure regulator
suspension:
team z tubular k member and tubular a arms
newer struts with coil overs
flaming river manual rack and pinion with bump steer
upr caster camber plates
welded ...
$20,000
Posted by: btack74
Post Date: June 4, 2017
Expires: September 24, 2017
More...
