shift solenoid replacement
Old Jul 3, 2006 | 05:38 PM
67camaro's Avatar
Default shift solenoid replacement
Anybody have any direction on replacing the shift solenoids on a 93 sts. Are they accessible through the bottom pan, or do I have to go in from the side cover.
Old Jul 3, 2006 | 09:05 PM
FLCaddytech's Avatar
Default RE: shift solenoid replacement
Assuming you have a northstar/4t80e then they are accessed from the bottom.
If detailed directions are needed i would suggest a service manual.
The entire lower valve body/channel plate must be removed and disassembled.
Also the lower channel plate gasket should be replaced.
If you have specific questions i will help the best i can, but this is not a doityourself type repair IMHO.
Please don't take offence to this, you may be well qualified for the task.
I just feel this type of repair should be done "by the book", at least the first time.
Jason
Sep 6, 2011 09:01 PM
El Diggy
Automatic Transmissions
Mar 19, 2009 11:42 PM
dksob81
Mar 7, 2009 06:00 AM
rbud87
Jul 25, 2007 02:50 PM
LCD
Aug 20, 2006 11:09 PM
