OTHER ground under rear seat
Old Aug 31, 2007 | 09:12 PM
Default OTHER ground under rear seat
basically................. for what is that a ground for......?? or, where is it coming from......??
does it have anything to do with my fuel gauge going wacky?
thanks
Old Aug 31, 2007 | 09:13 PM
Default RE: OTHER ground under rear seat
sorry....99sts
Old Sep 1, 2007 | 07:59 PM
ORIGINAL: rickyd
thanks
any given ground completes any given electrical circuit.
should a given ground lose its connection, lacking a contingency secondary ground, that circuit will either shut down or fail,
should a given ground become an intermittent connection, so will the circuits served by that ground.
Old Sep 4, 2007 | 09:07 AM
stealth, sorry i didnt explain myself.....there are two grounds under rear seat...99sts.... one is main, and off of batt. the other comes out of the trunk, and is attached on floor behind driver. question: what is that ground, grounding.......?
Old Sep 4, 2007 | 10:19 AM
not having a circuit diag for your car, i dont know the specifics.
the main ground basically grounds the battery to the car chassis/frame,
the other probably makes sure a metal section of the car that may be insulated
by rubber moutns is also well grounded.
when it comes down to it, every sheet metal part of your car is part of an electrical circuit.
regardless, if you are having electrical issues, i would remove both, clean and lube
(dielectric) the terminals and hardware. then you be good for another 20 years.
if you havent, i suggest you read the FAQ on e-ghosts in our FAQ section.
Old Sep 4, 2007 | 10:55 AM
well i have done just that with those two grounds, and am still having a wacky fuel gauge in the morning. that is untill the sun comes out and things get dryed off....... any suggestions? i guess im going to have to redo all 15 grounds on that car.......
thanks
brock402
Aug 15, 2011 11:43 PM
hotrod
Oct 28, 2008 01:31 PM
hotrod
Mar 5, 2008 07:35 PM
olfrankr
Oct 27, 2004 10:42 PM
