GM Cadillac Aurora Northstar recalls question
Old Feb 1, 2008 | 11:34 AM
Default GM Cadillac Aurora Northstar recalls question
stealth, is xu936769 99sts,4.6 n* included in the recall? i am not sure what you meant "break point" tx
rick
just got off phone w/ Cadillac dealer, then to my bud Joe P. and found it not to be included in recall...... i understand now what vin break means........thanks stealth
rick
Old Feb 1, 2008 | 06:13 PM
Default RE: GM Cadillac Aurora Northstar recalls question
ORIGINAL: rickyd
rick
rick
slowroll is the man to ask !
me not know.
Old Feb 1, 2008 | 06:24 PM
VIN break means within the sequence number (last six digits) will fall between first and last numbers inclusive. Likely GM got a run of mismachined blocks. Engineers who inspected warranty cores, found after an unusal amount of warranty failures they all came from the same order. Then decided to recall cars built while that order was at the plant. Recall was done reduce the chance owners would suffer engine failure in or out of warranty due to machining. There may be cars out there that recall has not been done yet. As well a car that had blown head gasket that vin falls in the recall, if when block is checked the thread depth is correct, the recall would not replace engine nor re-imburse head gasket replacement.
SimpsonTruckDriver
Jun 18, 2014 07:58 AM
Swishaa
Automatic Transmissions
Jan 12, 2011 07:26 AM
Feb 1, 2008 09:06 AM
May 24, 2007 05:42 PM
Apr 5, 2007 06:11 PM
