Emergency Brake??
Old Dec 22, 2007 | 11:30 AM
dpv1977's Avatar
Default Emergency Brake??
I have a 2000 STS that failed inspection because the emergency brake would not work. I haven't been able to find any info about it. The manual refers only to a parking brake that you push the same time as the brake pedal and that is working fine, it releases properly when shifting to drive. When in gear the "emergency brake" pedal does nothing. Any help or guidance would be greatly appreciated....thankyou
Old Dec 22, 2007 | 10:32 PM
Default RE: Emergency Brake??
Parking brake should hold with foot holding park brake pedal down in gear at idle. With rear tires off the ground. Appy parking brake see if either wheel will hold. If neither one hold check brake cable adjustment and operation of actuators on rear calipers. If one holds and not the other it may be caliper. If cable will fully actuate lever on rear caliper and pads wont hold rotor, you will need to replace rear calipers. It is recommend to replace hydralic brake componets in pairs...right and left.
Old Dec 25, 2007 | 08:22 PM
dpv1977's Avatar
I will do all you've suggested, thankyou again slowroll
Old Oct 6, 2009 | 12:43 PM
mazzman's Avatar
Default How do you change emergancy brake foot pedal assembly on 98 Cadillac STS?
How do you change emergancy brake foot pedal assembly on 98 Cadillac STS? I have a new unit but need instructions (hopefully pictures) to remove and replace the unit under the dash.
Old Nov 4, 2009 | 10:53 PM
exactly why are you trying to change the foot pedal assy?
i hope is not due to failure to release which can be caused by a failed solenoid activated via the shifter.
Old Nov 5, 2009 | 09:37 AM
mazzman's Avatar
Stomper,
In order to release the emergency brake, I have to go under the dash and push the lever. Is it only the selenoid?
MAZZMAN
Old Nov 5, 2009 | 10:00 AM
Stomper,
In order to release the emergency brake, I have to go under the dash and push the lever. Is it only the solenoid?
MAZZMAN
yes !
that is the "manual" release for when the automatic system fails
also, some cars also have a vacuum system.
I dont know which system you got.
Old Nov 6, 2009 | 11:14 PM
Mrmojorisin's Avatar
He has a 98 STS
Eldo69
Jul 11, 2010 12:49 PM
brian7125
Feb 20, 2010 04:31 PM
99STSGUY
Jan 21, 2009 08:29 AM
newfiedew
Aug 18, 2008 10:49 AM
