2010 STS with 20 plus codes!
Old Mar 16, 2018 | 07:17 PM
SuperDuty04's Avatar
Default Erase thread erase thread
Erase no longer needed
Old Mar 17, 2018 | 09:26 PM
CWB's Avatar
CWB
I would start by checking 3 general areas. 1. BATTERY - Check the freeze frame to see the battery voltage. Also connect a 10 amp battery charger overnight and while still connected - Start car. If the battery voltage shows below 12.1 volts at any time, then replace the battery (or at least remove battery and take somewhere for a COMPUTERIZED load test with a printout. 2. Check all the ground connections. Particularly the one on the passenger fender well near the battery on the passenger side and the one on the drivers side near the bottom corner of the radiator. 3. There is a connection under the drivers seat that is subject to corrosion. Check, clean, repair, replace. Good Luck
PS: Color? adaptive cruise? 1SG? Want to sell it?
Old Mar 17, 2018 | 09:38 PM
Silver
no idea
no idea
yes
Old Mar 19, 2018 | 05:02 PM
Mods erase my thread, car was traded in. Thankyou
AlaskaHome1959
Oct 4, 2017 10:17 PM
Jason
Sep 6, 2011 09:01 PM
haaseman
Jan 13, 2009 08:18 PM
CateraRacer
May 29, 2008 10:59 AM
Vehicular Projects
Apr 1, 2007 11:19 PM
