1991 Seville STS brake issues
Old Feb 10, 2008 | 06:28 PM
pcfixersts's Avatar
Default 1991 Seville STS brake issues
I need to know the PROPER procedure for bleeding the brakes, including the sequence, how to pump the brake pedal - everything
I have replaced all the disks and pads and the back calipers and am planning to replace the master cylinder if I can get the pedal to be firm. It;s really spongy and won't hold the car.
ANY help would be appreciated
Daniel
Old Feb 11, 2008 | 08:20 AM
Default RE: 1991 Seville STS brake issues
hey pcfixersts....welcome to the Forum.....as far as your brake issue, after replacing all you have, and you have a spongy pedal still? it seems to me that the master cylinder is the reason for the spongy pedal........ though, brakes are not me, so.....hang in and one of the Forums Techs will advise you soon....... good luck and again welcome
Old Feb 11, 2008 | 10:09 PM
As a gerneral rule bleeding order RR,LR,RF last LF. Does car have ABS? If you have no,none,or nada experience at all I recommend find someone who does or tow it to a shop, even a Votech (low cost option unless your in a hurry, normally no labor charges just materials. Teachers are ASE certified.)
Grant A. Van Vranken
Oct 26, 2013 06:21 PM
Alfonzo
Dec 15, 2009 12:32 PM
abaines12345
Jun 8, 2008 11:02 PM
dazcad
Jul 16, 2006 05:38 PM
dazcad
Jul 16, 2006 05:32 PM
