factory fog lights switch
Hello, 2013 srx premium is the auto I'm referring to. Does one with factory foglamps have a different switch than the ones that are not equipped with lamps? I want to purchase a set however all I see are ones with a separate add-on switch .My long time collision shop owner said that other cars have an in-dash switch you can pull the center part of the switch and they come on. That sounds like a much cleaner look. If that is correct does anyone know the part numbers for the switch and the lamps/housing? Is GMparts.com the best place to order them from or another place?
I installed the blackened inside headlamps and would like go a step further with a fog lamp installation.
I would like the yellow (not amber) bulb or lens but that is probably not going to be available....ya never know if you don't inquire.
thanks everyone, elodoedwardo
